製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Go from Module Selection to a Working Project
Discover how the Wio family supports your journey from early evaluation to real-world deployment, with setup guides, reference designs, SDKs, KiCad libraries, hands-on testing, and projects built by developers. Explore connectivity options across LoRa, Wi-Fi, BLE, GNSS, and more, then find the module and purchasing path that match your technical requirements, location, and development stage.
This compact unit offers versatile (G)FSK and Long Range support, compatibility with LoRaWAN® Class A/B/C protocols, and a broad frequency range including EU868/US915/AU915/AS923/KR920/IN865. Easily connect with LoRaWAN servers like TheThingsStack and Chirpstack.
  • Ultra-Low Power Consumption: In transmit mode, the operating current is only 26mA.
  • High Performance: The transmit power is 14dBm @868/915MHz; -136.5dBm sensitivity for SF12 with 125KHz BW
  • Long-Distance Communication: Benefit from a 158dB link budget to ensure a seamless connection over extended distances.
  • Abundant peripherals: Equipped with a variety of GPIO interfaces like UART, I2C, and ADC, this module offers great flexibility for developers looking to expand peripherals.
  • Certified and Trusted: Wio-E5-LE is FCC and CE-certified, guaranteeing compliance with regulations and standards.
  • Easy to Use: Has built-in AT command firmware and supports custom product development using an SDK.
仕様
Items
Parameter
Specifications
Unit
Structure
Size
12(W) X 12(L) X 2.5(H)
mm
Package
28 pins, SMT
Electrical
Characteristics
power supply
3.3V type
V
Sleep current
2.1uA (WDT on);
uA
Operation current
(Transmitter+MCU)
26mA @14dBm in 868MHz type
mA
26mA @14dBm in 915MHz type
Operation current
(Receiver+MCU)
6.7mA @BW125kHz, 868MHz type
mA
6.7mA @BW125kHz, 915MHz type
Output power
14dBm max @868MHz
dBm
14dBm max @915MHz
Sensitivity
@SF12, BW125kHz
dBm
Fr(MHz)
min
type
max
868
-135
-137
915
-135
-137
Harmonics
<-36dBm below 1GHz
dBm
<-40dBm above 1GHz
dBm
Interface
RFIO
RF port
UART
3 group of UART, include 6 pins
I2C
1 group of I2C, include 2 pins
ADC
1 ADC Input, include 1pins,12-bit 1Msps
NRST
Manual reset pin input
SPI
1 group of SPI, include 4 pins
Working Temperature
-40℃ ~ 85℃
ハードウェア概要
The Wio-E5-LE LoRa module's Stamp Hole form factor allows seamless integration into a device's mainboard, eliminating the need for extra components. With versatile GPIO interfaces including UART, I2C, and ADC, developers have the flexibility to expand peripherals effortlessly. Furthermore, these pre-certified modules expedite the certification and regulatory approval process for your end products.
For beginners, the Wio-E5-LE simplifies the creation of prototypes or applications with its built-in AT command firmware, requiring just a few basic commands. Meanwhile, experienced developers can harness the SDK to design customized products.
Seeed is the official ST Authorized Partner to bring you STMicroelectronics solutions from Modules to Development Boards, one-stop prototyping services with Seeed Fusion, and integration customization.
If you want to learn about Long Range and its features such as network architecture and applications, you can check out this article LoRapedia, which introduces Long Range and Long Range in detail, It explains what Long Range is, how it works, and its pros and cons.
Wio-E5 Series Comparison
Note
Should you prioritize transmission distance and be less concerned about power consumption, the Wio-E5 would be an ideal choice. Conversely, if minimizing power consumption is your primary objective and your operational range is relatively short, the Wio-E5-LE would be a more fitting selection.
用途
Would like to learn more about the application scenarios of the Wio-E5 series module? Please check out the following real-world use cases:
After designing your own Long Range devices with this Wio-E5 module, you can get your designs verified quickly with Seeed Fusion PCB and PCBA services, which can help turn your designs into prototypes in a few days. And when the design is verified, Seeed agile manufacturing services will help you scale up the prototypes into mass production, with services from Design for Manufacturing, procuring raw materials, to mass production and global shipment, and many services in between.
Development Tools
We also offer a range of development boards that make it easier for you to first verify your ideas and then use modules to build your own products. We have designed Grove Wio-E5, Wio-E5 mini Dev Board, Wio-E5 Dev Kit that you can choose according to your needs to speed up your project development.
ODM & OEM
With decades of ODM & OEM experience, our engineers and product experts are proficient in delivering customization services for popular open-source hardware platforms – NVIDIA® Jetson™, Raspberry Pi ®, Beagleboard ®, and more. Use the Wio-E5 series module to create industrial-grade sensors or development boards for rapid AIoT implementation.
Feature product using Wio-E5
Such as our SenseCAP S210x series products
We're dedicated to supporting you and streamlining your idea-to-product journey. We are ready to bring your product concept to the market with Seeed Studio’s industrial capabilities from design, manufacturing, testing, certification, global distribution, and marketplace. SenseCAP S210x series products are made based on this module, which makes good use of the ultra-low power consumption of this module, and is deployed in many places, for more information, please contact [email protected].
Note
If you have a large quantity request or need any further information on Seeed IIoT products and services, please don't hesitate to contact us directly at [email protected] or click here and we'll be happy to offer you our best discount price. We are excited to see you can scale up and expand your business with our products and services.
認証
HSCODE8517709000
USHSCODE8517620090
UPC
EUHSCODE8517180000
COOCHINA
Wio-E5-LE LoRa Module (Bulk) - STM32WLE5JC, ARM Cortex-M4 and SX126x embedded, supports LoRaWAN on EU868 & US915
SKU 114993120
Wio-E5-LE LoRa module has a single-core STM32WLE5JC chip, Cortex M4 MCU, and SX126X. It uses 84% less power for transmission compared to the Wio-E5. The ultra-low power consumption of the Wio-E5-LE makes it very energy efficient, this power-saving design makes the Wio-E5-LE well-suited for applications needing minimal power usage.
JPY¥1028.00
