製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Go from Module Selection to a Working Project
Discover how the Wio family supports your journey from early evaluation to real-world deployment, with setup guides, reference designs, SDKs, KiCad libraries, hands-on testing, and projects built by developers. Explore connectivity options across LoRa, Wi-Fi, BLE, GNSS, and more, then find the module and purchasing path that match your technical requirements, location, and development stage.
Note
In the antenna selection for Wio-E5, we provide the following two references to ensure improved RF performance and compliance with CE/FCC regulations:
1. Dipole Antenna (up to 2.0 dBi): This antenna is utilized for Wio-E5 certification. For more information, please refer to the certification report or SKU 113070002.
2. Spring-loaded Antenna (up to 1.1dBi): This is the antenna employed by the SenseCAP S210X LoRaWAN sensor.
This ultra-compact module has extremely low power consumption and is capable of supporting both (G)FSK and Long Range. Its built-in AT command firmware, makes it easy for developers to build their prototypes or applications. It can easily support LoRaWAN® protocols and a variety of frequency plans, making it an ideal solution for Long Range sensor nodes and a range of wireless communication applications. Whether you need to set up Wireless Meter Reading, IoT Nodes, or a Sensor Network, the Wio-E5 is perfectly suited for low power wide area IoT scenarios.
With this module, you can connect to different LoRaWAN server platforms like TheThingsStack, Chirpstack, and others.
Note
If you have a large quantity request or need any further information on Seeed IIoT products and services, please don't hesitate to contact us directly at [email protected] or click here. We'll be happy to offer you our best discount price. We are excited to see you can scale up and expand your business with our products and services.
  • High Performance: The transmit power up to 22dBm @868/915MHz; -136.5dBm sensitivity for SF12 with 125KHz BW.
  • Long Distance Use: 158dB link budget.
  • Wireless Connectivity: Embedded Long Range protocol, supports global Long Range frequency plan.
  • Abundant peripherals: Equipped with a variety of GPIO interfaces like UART, I2C, and ADC, this module offers great flexibility for developers looking to expand peripherals.
  • Easy to Use: Has built-in AT command firmware and supports custom product development using an SDK.
  • FCC, CE, IC, Telec, WPC and RCM Certified
仕様
Items
Parameter
Specifications
Unit
Core
MCU
ARM Cortex M4
Storage
256KB Flash, 64KB SRAM
KB
Structure
Size
12(W)*12(L)*2.5(H)
mm
Package
28 pins, SMT
Electrical Characteristics
power supply
3.3V type
V
Minimum sleep current
2.1uA(SOC)
uA
Operation current (Transmitter+MCU)
50mA @10dBm in 434MHz type
mA
111mA @22dBm in 470MHz type
111mA @22dBm in 868MHz type
Operation current (Receiver+MCU)
6.7mA @BW125kHz, 868MHz type
mA
6.7mA @BW125kHz, 434MHz type
6.7mA @BW125kHz, 470MHz type
Output power
10dBm max @434MHz
dBm
22dBm max @470MHz
22dBm max @868MHz
Sensitivity
@SF12, BW125kHz
dBm
Fr(MHz)
min
type
max
434
-134.5
-136
470
-136.5
-137.5
868
-135
-137
Harmonics
< -36dBm below 1GHz
dBm
< -40dBm above 1GHz
dBm
Interface
RFIO
RF port
UART
3 group of UART, include 2 pins
I2C
1 group of I2C, include 2 pins
ADC
1 ADC Input, include 1 pins, 12-bit 1Msps
NRST
Manual reset pin input
SPI
1 group of SPI, include 4 pins
Working Temperature
-40℃ ~ 85℃
ハードウェア概要
The Wio-E5 series is a high-powered long-range module designed with a convenient Stamp Hole form factor, allowing easy integration into a device's mainboard without requiring extra components. It supports a variety of frequency plans, including EU868/US915/AU915/AS923/KR920/IN865, and is compatible with LoRaWAN® Class A/B/C protocols. What's more, this module is pre-certified, making it cost-effective and swift for your entire device to obtain certifications and approvals from any regulatory agency.
The Wio-E5 has built-in AT command firmware, making it easy to create prototypes or applications with just a few simple commands for beginners. Experienced developers, on the other hand, can use the SDK to develop customized products.
Seeed is the official ST Authorized Partner to bring you STMicroelectronics solutions from Modules to Development Boards, one-stop prototyping services with Seeed Fusion, and integration customization.
If you want to learn about Long Range and its features such as network architecture and applications, you can check out this article LoRapedia, which introduces Long Range and Long Range in detail, It explains what Long Range is, how it works, and its pros and cons.
If you're looking for a tool for both Long Range sensor network management and Car Hacking, our newly released Wio-E5 CAN Development Kit is based on the Wio-E5 module, with a built-in CAN controller MCP2515 that supports CAN FD, CAN2.0, and RS485 communication. It's a versatile and useful tool that provides an excellent user experience.
Development Tools
Wio-E5Grove Wio-E5Wio-E5 mini Dev Board Wio-E5 Dev Kit that you can choose according to your needs to speed up your project development.
less than 1000 pieces will be sent in cut tape form and quantities of 1000 pieces or more will be sent on reels of 1000 pieces, with the remainder sent in tape form.
Product Label Change Notice
The label on the Wio-E5 module will be updated to a new version that includes the TELEC certification logo. As a result, products that include the Wio-E5 module (such as the Grove Wio-E5, Wio-E5 mini, and Wio-E5 development kit) will have a new label on the Wio-E5 module in production batches after May. During the transition period, please note that there may be mixed deliveries. If you only accept new labels that show the TELEC logo, please make a note when ordering related products.
認証
HSCODE8517799000
USHSCODE8517620090
UPC
EUHSCODE8471707000
COOCHINA
Wio-E5 LoRa Module (Tape Reel) - STM32WLE5JC, ARM Cortex-M4 and SX126x embedded, supports LoRaWAN on EU868, US915 and more
SKU 317990829
The Wio-E5 wireless LoRa module is embedded with the ST system-level package chip STM32WLE5JC, ARM Cortex M4 ultra-low power MCU, and Long Range SX126X. It supports EU868, US915 and more, making it suitable for wireless sensor networks and other IoT devices that require battery power, low power consumption and long range.
JPY¥1028.00
