製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Note
  • The carrier board is specially designed for working with Jetson TX2/ TX2i / TX1  modules and we will not include them inside.
  • We will not include a power cord, please choose a suitable form according to your country.
  • 400 pin SO-DIMM provided, module TX1/TX2-4GB/TX2-8GB/TX2i fitted
  • Compact size (86mm*60mm*23mm) saves precious space
  • Lightweight good for small AI or IoT Application
  • Compact & all-in-one design
  • Equipped with an anti-fall aviation plug that supports high currents
  • mPCIe/mSATA and Sim card slot, 4G communication allowance
  • SATA storage for SSD, best for small NVR
EX2-TX2 is a high-performance, interface rich NVIDIA Jetson TX series compatible carrier board, providing HDMI 2.0, Gigabit Ethernet, USB3.0, USB 2.0, micro USB  (OTG function), mPCIe/mSATA, SATA solid-state drive, CSI camera, 422, SD card, CAN, PIO, I2C, I2S fans and other rich peripheral interfaces are suitable for environments with strict environmental requirements, small size and powerful functions.
Basically, it works with an NVIDIA  module mentioned above to achieve graphic AI applications. To be more specific, with the NVIDIA Jetson TX series module assembled, it could support NVIDIA JetPack, which includes a board support package (BSP), Linux OS, NVIDIA CUDA®, cuDNN, and TensorRT™ software libraries for deep learning, computer vision, GPU computing, multimedia processing, and much more. It is suitable for small size AI graphical applications such as smart-city IoT edge devices, small NVR, Home robots, UAVs, Unmanned boats and Unmanned submarines which need to have a lightweight, low power consumption and small overall design.
Application
  • Home NVR
  • Home robots
  • UAVs
  • Unmanned boats
  • Unmanned submarines
Specifications
EX2-TX2 Connector Summary
Module
OS
Ubuntu 18.04/16.04
CPU
Dual-Core Denver 1.5 64-Bit CPU and ARM-A57
GPU
256-core NVIDIA Pascal GPU
Memory
8 GB 128-bit LPDDR4
Storage
32 GB eMMC 5.1 msata SSD/sata3.1 HDD
Power
12VDC 7.5W/15W
Display
MICRO HDMI
USB
USB-TYPE-A3.0*3,MICRO-USB2.0 *1
NETWORK
Gigabit Lan,WIFI,4G-LTE
interfaces
mPCIE/mSata/sata3.1 UART,422,GPIO,I²C,CAN*25V-PWM-FAN
Mechanical
87*60*33mm,143.5g
Temperature
-45℃-85℃(TX2-02)
Comparison among EX series carrier board
FeatureEX1 carrier boardEX2-TX2 carrier board EX1-Dual ethernet ports carrier board
Module Compatibility NVIDIA® Jetson™ Nano/NX/TX2 NX NVIDIA® Jetson™ TX series NVIDIA® Jetson™ Nano/NX/TX2 NX
So-DIMM260 Pin400 Pin260 Pin
PCB Size / Overall Size100mm*80mm86mm*60mm119mm*80mm
Display  1* Micro HDMI1* Micro HDMI1*HDMI
CSI Camera1*CSI//
Ethernet1x Gigabit Ethernet
(10/100/1000M)
1x Gigabit Ethernet
(10/100/1000M)
2x Gigabit Ethernet
(10/100/1000M)
USB4* USB 3.0 Type A
(Integrated USB 2.0);
2* USB 3.0 Type A
1* USB 3.0 Type A
1* USB 2.0
(4 Pin connector)
1* USB 2.0
1* USB Micro B1* USB Micro B1* USB Micro B
SATA/1 SATA/
M.2 Key M1*M.2 Key M//
M.2 Key E///
mPCL1* mPCIe1* mPCIe/
TF_Card/1* TF_Card1* TF_Card
SIM1* Sim card slot1* Sim card slot/
USB WIFI Mode1*USB 2.0 Wifi (Pre-installed )//
FAN1* FAN(5V PWM)1* FAN(5V PWM)1* FAN(5V PWM)
CAN1* CAN2* CAN/
Multifunctional port1* 24-Pin1* 26-Pin1* 16-Pin
Other multifunctional port10 Pin (I2C, I2S, GPIOs)422(UART 5 Pin)/
RTC//Battery not included
Supercapacitor1* Supercapacitor1* Supercapacitor/
Power DC 12V/5VDC 12VDC 5V
Other Power1* 4 Pin POE1* 2 Pin SATA 5V Power/
Operating Temperature-40° to +85°-45° to +85°-45° to +85°
Hardware Overview
Note
If you want to enter recovery mode, follow the below instruction:
  1. Connect the module to the board and the power,
  2. Press the‘ POW’ button once to power on,
  3. Press and hold the ’REC’ button and at the same time,
  4. Press the ‘RST’ button once to enter recovery mode. (Keep holding ‘REC’ for 2-3 seconds)
1 x  Carrier Board
1 x  Power Adapter 12V (Power cord not included)
ドキュメント
認証
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
EX2-TX2 Carrier Board for JetsonTX series with compact size and rich ports (SIM card, SATA, mPCLe ,etc.)
SKU 102110643
EX-TX2 is an extended carrier board specifically for the NVIDIA Jetson TX series. The rich peripheral interfaces make it suitable for end-to-end AI robot applications in manufacturing, logistics, retail, agriculture and other industries. With the powerful NVIDIA controlling module(not included) and its compact design, it is good for Video Analysis and Robotics like UAVs, Unmanned boats, Unmanned submarines, etc.
JPY¥28331.00
廃番
