製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
● Powerful AI Processing Capabilities: Utilizes WiseEye2 HX6538 processor with a dual-core Arm Cortex-M55 and integrated Arm Ethos-U55 neural network unit.
● Versatile AI Model Support: Easily deploy off-the-shelf or your custom AI models from SenseCraft AI, including Mobilenet V1, V2, Efficientnet-lite, Yolo v5 & v8. TensorFlow and PyTorch frameworks are supported.
● Rich Peripheral Devices: Includes PDM microphone, SD card slot, Type-C, Grove interface, and other peripherals.
● High Compatibility: Compatible with XIAO series, Arduino, Raspberry Pi, ESP dev board, easy for further development
● Fully Open Source: All codes, design files, and schematics available for modification and use.
How's the performance of Grove Vision AI V2?
To have a quick evaluation of this board's performance, we compared it to Seeed's other MCU-based vision AI boards - Grove Vision AI Module, XIAO ESP32S3 Sense in four areas:
(Image Credits: Mengdu)
These results clearly demonstrate that the Grove Vision AI V2 is a premium choice for high-performance vision processing.
What's on the board?
Already have your own XIAO board and camera? Choose Grove Vision AI Module V2. Prefer a prebuilt compact AI camera? Check out XIAO Vision AI Camera, or explore reCamera Basic for a more powerful standalone AI camera.
仕様
Specification of different OV5647 Camera Modules
Parameters
OV5647- 62 FOV Camera module
OV5647-67 FOV IR Camera module
OV5647-160 FOV IR Camera module
Still resolution
5 Megapixels
FOV
62
67
160
Video modes
1080p@30fps 720p@60fps
Sensor
OV5647
Sensor Resolution
2592 × 1944 pixels
Pixel Size
1.4 µm x 1.4 µm
Focal Length
3.4 mm (adjustable)
3.6 mm (adjustable)
3.15 mm (adjustable)
Focal Ratio (F-Stop)
2.8
2.0
2.35
Power Supply
3.3 V (Pin 15)
Hardware Support
Raspberry Pi 3B / 3B+ / 4
Operating Temp
-20°C to 70°C
CMOS Size
1/4 inch
Size
25 x 23 x 9mm
38 x 38 x 18.4mm
(excluding lens)
25mm × 24mm ×18±0.5mm
Specification of Grove - Vision AI Module V2
Microcontroller
Himax WiseEye2 HX6538 processor featuring a dual-core Arm Cortex-M55 and integrated Arm Ethos-U55
Onboard Peripherals
PDM Microphone, SD Card Slot
Rich Interfaces
CSI, IIC, UART, SPI, and Type-C
Input Voltage
5V
Power Supply
dual 7-pin connector & Type-C
Rate
115200
I2C Interface
Seeed Studio XIAO & Arduino
Downloading & Firmware Burn Interface
Type-C
Frequency(ARM Cortex-M55 Processor(Big))
Up to 400MHz
Frequency(ARM Cortex-M55 Processor(Little))
Up to 150MHz
Frequency(ARM Ethos-U55 microNPU)
Up to 400MHz
Memory Card Interface
Up to 1x SD and SDIO host, support DS mode, up to 25MHz
Internal System Memory
● Configurable system memory, up to 2432KB
● 64KB boot ROM
ハードウェア概要
用途
  • Industrial automation: quality inspection, predictive maintenance, voice control, etc.
  • Smart city: equipment monitoring, energy management, etc.
  • Transportation: status monitoring, location tracking, etc.
  • Intelligent agriculture: environmental monitoring, etc.
  • Mobile IoT devices: wearable devices, handheld devices, etc.
How to use it?
SenseCraft AI is a platform that enables easy AI model training and deployment with no-code/low-code. It supports Seeed products natively, ensuring complete adaptability of the trained models to Seeed products. Moreover, deploying models through this platform offers immediate visualization of identification results on the website, enabling prompt assessment of model performance.
Ideal for tinyML applications, adding vision AI to your smart sensor with Grove Vision AI V2 is made easy with the SenseCraft AI. Effortlessly deploy off-the-shelf or custom AI models by connecting the device, selecting a model, and viewing identification results.
Join the Vision Revolution: Subscribe to our Newsletter for Exclusive Updates!
Scan the QR code or Vision Tech
部品リスト
Grove Vision AI V2
x1
Raspberry Pi OV5647 Camera Module
x1
Seeed Studio XIAO
x1
Grove Vision AI v2 Kit - with optional Raspberry Pi OV5647 Camera Module, Seeed Studio XIAO; Arm Cortex-M55 & Ethos-U55, TensorFlow and PyTorch supported
SKU E23011220
It is an MCU-based vision AI module powered by Himax WiseEye2, featuring Arm Cortex-M55 & Ethos-U55. TensorFlow and PyTorch frameworks are supported. Compatible with Arduino IDE and no code model deployment and immediate visualization of inference results with SenseCraft AI.
JPY¥4558.00
Grove - Vision AI Module V2 - Arm Cortex-M55 & Ethos-U55, TensorFlow and PyTorch supported, Arduino, Raspberry Pi, Seeed Studio XIAO, ESP-based dev board compatiblex1¥2531.00
OV5647-62 FOV Camera Module for Raspberry Pi 3B+4B x1¥1251.00
Seeed Studio XIAO ESP32-C3 x1¥776.00
