Note
This product is no longer available due to a shortage of materials, and we have another the same product - reComputer J1020 v2
reComputer J1020 is a powerful and compact intelligent edge box built with Jetson Nano production module, bringing modern AI performance to the edge. The built-in carrier board is the same dimension as the Jetson Nano Developer Kit, including 4xUSB 3, M.2 Key M, HDMI, and DP. The full system also includes a fan and a power adapter.
For AI beginners, if you would like to get critical AI skills and dive into deep learning. NVIDIA’s Deep Learning Institute (DLI) delivers practical, hands-on training and certification. Please also check out Seeed wiki guide including getting started with Jetson Nano and also building different projects.
For solution providers, reComputer J1020 is preinstalled with Jetpack 4.6.1, with rich set of I/Os, this AI box simplifies development and fits for deployment for edge AI solution providers working in video analytics, object detection, natural language processing, medical imaging, and robotics across industries of smart cities, security, industrial automation, smart factories.
reComputer series for Jetson are compact edge computers built with NVIDIA advanced AI embedded systems: J10 (Nano 4GB) and J20 (Jetson Xavier NX 8GB and Jetson Xavier 16GB). With rich extension modules, industrial peripherals, and thermal management, reComputer for Jetson is ready to help you accelerate and scale the next-gen AI product by deploying popular DNN models and ML frameworks to the edge and inferencing with high performance.
At Seeed Studio, you will find everything you want to work with NVIDIA Jetson Platform – official NVIDIA Jetson Dev Kits, Seeed-designed carrier boards, and edge devices, as well as accessories.
Welcome to check out our free Edge AI partner program. We are looking forward to leveraging local and global resources to accelerate next-gen AI products together with you.
Seeed is a reseller of NVIDIA embedded systems and a preferred partner of the NVIDIA Jetson ecosystem for edge AI. Explore more carrier boards, full system devices, customization services, use cases, and developer tools at Seeed Jetson Ecosystem! Welcome to check out our free Edge AI partner program. We are looking forward to leveraging local and global resources to accelerate next-gen AI product together with you.
Product | reComputer J1020 | ||
Module | Jetson Nano 4GB (production version) | Nano (not production version) | |
Storage | 16 GB eMMC | MicroSD (Card not included) | |
SD Card Slot | Included (On the carrier board) | - | Included (On the module) |
Video Encoder | 4K30 | 2x1080p60 | 4x1080p30 | 4x720p60 | 9x720p30 (H.265 & H.264) | 4Kp30 | 4x 1080p30 | 9x 720p30 (H.264/H.265) | |
Video Decoder | 4K60 | 2x 4K30 | 4x 1080p60 | 8x 1080p30 | 9x 720p60 (H.265 & H.264) | 4Kp60 | 2x 4Kp30 | 8x 1080p30 | 18x 720p30 (H.264/H.265) | |
Gigabit Ethernet | 1*RJ45 Gigabit Ethernet Connector (10/100/1000) | ||
USB | 1 * USB 3.0 Type A; 2 * USB 2.0 Type A; 1 * USB Type C for device mode; 1 * USB Type C for 5V power input | 4 * USB 3.0 Type-A ; 1 * Micro-USB port for device mode; | 4 * USB 3.0 Type-A; 1 * Micro-USB port for 5V power input or for device mode |
CSI Camera Connect | 2*CSI Camera (15 pos, 1mm pitch, MIPI CSI-2 ) | ||
Display | 1*HDMI Type A | 1*HDMI Type A; 1*DP | 1*HDMI Type A; 1*DP |
FAN | 1* FAN (5V PWM) | ||
M.2 KEY E | 1*M.2 Key E | 1*M.2 Key E (Disabled) | 1*M.2 Key E |
M.2 KEY M | - | 1*M.2 Key M | - |
RTC | 1*RTC Socket | - | |
Multifunctional port | 1* 40-Pin header | ||
Power Supply | USB-Type C 5V⎓3A | DC Jack 12V/2A | DC Jack 5V⎓4A; Micro-USB 5V⎓2A |
Mechanical | 130 mm x 120 mm x 50 mm (with case) | 130mm x120mm x 50mm (with case) | 100 mm x 80 mm x 29 mm |
Note
If use some GPIO libraries that causes floating voltage 1.2V~2V , GPIO issues on the carrier board could happen as the normal voltage should be 3V.For both beginners and experts, it is designed to help you to build your next-gen autonomous machine at the edge.
reComputer J1010 and J1020, powered by Jetson Nano, are ideal for learning AI and building AI applications for image recognition, object detection, pose estimation, video processing, and many more. Check out the following application example with tutorials!
Find in the Jetson Community Resources page tools and tutorials the community has created to power your development experience, and check out the Community Projects page to inspire your next project!
Jetson software stack begins with NVIDIA JetPack™ SDK which provides a full development environment and includes CUDA-X accelerated libraries and other NVIDIA technologies to kickstart your development.JetPack includes the Jetson Linux Driver package which provides the Linux kernel, bootloader, NVIDIA drivers, flashing utilities, sample filesystem, and toolchains for the Jetson platform. It also includes security features, over-the-air update capabilities, and much more.
Enable secure OTA and remote device management with Allxon. Unlock 90 days free trial with code H4U-NMW-CPK.
With Jetson Nano, developers can use highly accurate pre-trained models from TAO Toolkit and deploy with DeepStream. Jetson Nano can achieve 11 FPS for PeopleNet- ResNet34 of People Detection, 19 FPS for DashCamNet-ResNet18 of Vehicle Detection, and 101 FPS for FaceDetect-IR-ResNet18 of Face Detection.
Jetson Xavier NX can achieve 172 FPS for PeopleNet- ResNet34 of People Detection, 274 FPS for DashCamNet-ResNet18 of Vehicle Detection, and 1126 FPS for FaceDetect-IR-ResNet18 of Face Detection. Benchmark details can be found on NVIDIA®’s DeepStream SDK website.
Reference: Jetson series benchmark for Deepstream: end-to-end application performance from data ingestion, decoding, image processing to inference
If you are developing an application that requires processioning multiple video streams at high resolution while performing ASR/NLP or other GPU-related tasks (CUDA enabled SLAM for example), then its deep learning accelerators can take on CNN inference and leave GPU for other tasks – TX2 or Jetson Nano maybe not satisfied. We are more recommend reComputer J20 powered by NVIDIA Jetson Xavier NX. Check our comparison blog here.
Nearly the same functional design as Jetson Nano Developer Kit
Seeed reference carrier board for J1020 is a high-performance, interface-rich NVIDIA Jetson Nano compatible carrier board, providing HDMI 2.0, Gigabit Ethernet, USB 3.0, USB 2.0, CSI camera, GPIO, I2C, I2S, fans, and other rich peripheral interfaces.
The back screw holes allow you to hang the product as you need. We also provide other editions case like blue, silver and silver mental, whose stackable structure allows you to stack more middle layers to create rooms very easily.
Note
| Acrylic Cover | x1 |
| Aluminum Frame | x1 |
| Jetson Nano module | x1 |
| Heatsink | x1 |
| A206 Carrier board | x1 |
| 12V/2A Power adapter (with 5 interchangeable adapter plugs) | x1 |
