製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Card-sized microcontroller: (4 x 5cm) Easy to use & carry, designed for kids and beginners
  • Wireless Capability: Built-in 2.4GHz micro:bit radio and BLE Bluetooth 5.0
  • Rich Peripheries: Built-in buttons, MEMS microphone, speaker, touch-sensitive logo, accelerometer
  • Beginner Friendly: Programmable Onboard 25 red LEDs for inter that can be used for interactions
  • Completely Programmable: Support C++, MakeCode,Python,and Scratch software
  • Notched Connector for easier connections
Micro:bit v2.2 is a card-sized microcontroller designed for kids and beginners learning how to program, letting them easily bring ideas into DIY digital games, interactive projects, and robotics. You can use your BBC micro:bit for all sorts of cool creations, from robots to musical instruments. The possibilities are endless.
You can code, customize, and control micro:bit to bring your digital ideas, games, and apps to life. Measuring 4cm by 5cm, and designed to be fun and easy to use, users can create anything using micro:bit, from games and animations to scrolling stories at school, at home, and on the go. All you need is imagination and creativity.
Micro:bit v2.2 has a lot of features and is completely programmable. Each of its LEDs can be individually programmed. It is also equipped with a MEMS microphone, speaker, and touch-sensitive logo. If you want to realize wireless projects, it is equipped with a 2.4GHz micro:bit radio and BLE Bluetooth 5.0.
Also, It has 25 red LEDs that can flash messages and two programmable buttons that can be used to control games or pause and skip songs on a playlist. micro:bit v2 can also detect motion and tell you in which direction you’re heading in with the help of the onboard accelerometer.
Note
The difference between Micro-Bit SBC V2.2 and Micro-Bit SBC V2.0 is the difference in the USB interface driving chip and there will be a negligible influence.
Expand Micro:Bit
To help you explore more functionality, Seeed Studio has launched micro:bit expansion boards to plug and play with functional Grove modules, providing BitStarter Kit, Inventor Kits for enthusiatic learners and developers. You can also find the related free tutorials to show you how to develop from the very beginning.
Furthermore, Seeed Studio came up with some maker ideas and use Micro:Bit to build some compatible accessories, including BitPlayer, BitCar, RobotBit, BitWear, Kittenbot and so on.
If you want an even smaller microcontroller, you can check our Seeed Studio XIAO series.
Specifications
SpecificationDetails
ProcessorNordic Semiconductor nRF52833
Memory512KB Flash, 128KB RAM
InterfaceNXP KL27Z, 32KB RAM
MicrophoneMEMS microphone and LED indicator
AccelerometerST LSM303AGR
SpeakerOn-board speaker
Logo touchTouch-sensitive logo
Edge Connector25 pins. 4 dedicated GPIO, PWM, I2C, SPI and ext.power. 3 ring pins for connecting crocodile clips/banana plugs. Notched for easier connection
I2CDedicated I2C bus for peripherals
Wireless2.4GHz micro:bit Radio/BLE Bluetooth 5.0
Power5V via micro-USB port, 3V via edge connector or battery pack, LED power indicator, Power off (push and hold the power button
Current available200mA available for accessories
Motion SensorST LSM 303
SoftwareC++, MakeCode, Python, Scratch
Size5cm(w) x 4cm(h)
Hardware Overview
Comparison between the current version (v1.5) and the latest version (v2.2)
 Current Version (v1.5)Latest Version(v2.2)
ProcessorNordic Semiconductor nRF51822Nordic Semiconductor nRF52833
Memory256KB Flash, 16KB RAM512KB Flash, 128KB RAM
InterfaceNXP KL26Z, 16KB RAMNXP KL27Z, 32KB RAM
MicrophoneN/AMEMS microphone and LED indicator
SpeakerN/AOn-board speaker
Logo touchN/ATouch-sensitive logo
Edge Connector25 pins. 3 dedicated GPIO, PWM, I2C, SPI and ext.power. 3 ring pins for connecting crocodile clips/banana plugs25 pins. 4 dedicated GPIO, PWM, I2C, SPI and ext.power. 3 ring pins for connecting crocodile clips/banana plugs. Notched for easier connection
I2CShared I2C busDedicated I2C bus for peripherals
Wireless2.4GHz micro:bit Radio/BLE Bluetooth 4.02.4GHz micro:bit Radio/BLE Bluetooth 5.0
Power5V via micro-USB port, 3V via edge connector or battery pack5V via micro-USB port, 3V via edge connector or battery pack, LED power indicator, Power off (push and hold power button
Current available90mA available for accessories200mA available for accessories
Motion SensorST LSM 303ST LSM 303
SoftwareC++, MakeCode, Python, ScratchC++, MakeCode, Python, Scratch
Size5cm(w) x 4cm(h)5cm(w) x 4cm(h)
Board Changes
Speaker: Addition of a speaker at the back of the board, but you need to carefully check when accessories are mounted closer to the board than the depth of the current JST connector. By default, the micro:bit will output sound to both the edge connector pins and the onboard speaker. If your accessory makes use of a speaker, you may wish to disable the onboard speaker. This will need to be done in software.
Microphone: Addition of a rear-mounted MEMS microphone with a sound input hole on the front of the board, with a microphone activity LED. Make sure not to cover the microphone and the microphone LED when mounting on accessories.
Touch-sensitive logo: Addition of capacitive touch support to the micro:bit logo which is made of gold plated copper. Capacitive touch is used for the large pins on the micro:bit v2 as opposed to the resistive touch present in the micro:bit v1.5.
Antenna: Change of position of the antenna with an angle and coating it with copper to make it more visible. If your accessory makes use of radio or Bluetooth, it’s better to test your software packages with both board revisions.
Hardware Changes
I2C Bus: Addition of dedicated external I2C lines from the nRF52 of micro:bit v2 to use with accessories as opposed to the shared I2C bus on the micro:bit v1.5
Power: micro:bit v2 can be powered from the two lozenge-shaped pads on the rear of the board and the 3V/GND pins. The nRF52 supplies 300mA to drive the board. 100mA is reserved for powering onboard components. 200mA is then available for accessories.
Software Changes
MakeCode extensions: If your MakeCode extension makes use of mBed or the DAL, you may need to revise them to be compatible with CODAL and both revisions of the board. The latest revision no longer makes use of mBED.
Python modules: Additional memory helps to have more space to create Python modules to work with your accessories and the micro:bit.
  • 1 x micro:bit v2
  • 1 x User guide
ドキュメント
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
Micro:Bit V2.2- Card size MCU with Onboard Speaker, Accelerometer, MEMS microphone,2.4GHz radio/ BLE 5.0
SKU 102991634
Micro:bit v2.2 is a card-sized microcontroller designed for kids and beginners learning how to program, letting them easily bring ideas into DIY digital games, interactive projects, and robotics. With Rich Peripheries, 2.4GHz ratio and Bluetooth 5.0, the possibilities are endless.
JPY¥3625.00
