おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Enhanced Connectivity: Combines 2.4GHz Wi-Fi 6 (802.11ax), Bluetooth 5(LE), and IEEE 802.15.4 radio connectivity, allowing you to apply the Thread and Zigbee protocols.
  • Matter Native: Supports building Matter-compliant smart home projects thanks to its enhanced connectivity, achieving interoperability
  • Security Encrypted on Chip: Powered by ESP32-C6, it brings enhanced encrypted-on-chip security to your smart home projects via secure boot, encryption, and Trusted Execution Environment (TEE)
  • Outstanding RF performance: Has an on-board antenna with up to 80m BLE/Wi-Fi range, while reserving an interface for external UFL antenna
  • Leveraging Power Consumption: Comes with four working modes, with the lowest being 15 μA in deep sleep mode, while also supporting lithium battery charge management.
  • Dual RISC-V Processors: Incorporates two 32-bit RISC-V processors, with the high-performance processor running up to 160 MHz, and the low-power processor clocking up to 20 MHz
  • Classic XIAO Designs: Remains the classic XIAO designs of the thumb-size form factor of 21 x 17.8mm, and single-sided mount, making it perfect for space-limited projects such as wearables
  • Seamless integration with mainstream Cloud Platforms: ESP Rain Maker, AWS IoT, Microsoft Azure, and Google Cloud
Production-Ready Design with Fusion PCBA Support
Being the 8th member of the Seeed Studio XIAO family, XIAO ESP32C6 remains the classic XIAO design. All these features make it a perfect fit for either space-limited projects such as wearables, or a production-ready unit for your PCBA designs. With our Seeed Studio Fusion services, you can access competitive one-stop PCBA manufacturing, component sourcing, and testing, plus free DFA/DFM review to reduce manufacturing risks and accelerate the journey from prototype to production.
Note
XIAO SoM User Manual open-sources all hardware and software materials of XIAO, providing professional product design guidelines to help you accelerate ideas off the ground, streamline product design, providing a seamless experience from module selection to mass production. You can check here to see more info.
Starter Kit with free Course for all Electronics Neophytes and Enthusiasts
Seeed Studio has provided the Grove Starter Kit along with free and detailed courses for you quickly get started with microcontrollers and electronics, regarding all the Seeed Studio XIAO boards, promising you a great learning experience.
Not only programming but also electronics knowledge is not required, you will be taken step by step, from understanding the basic concepts to exercising the simple projects individually, finally being able to build complex, interesting, wearable projects on your own, owing a practical electronic product prototype from the course.
You can have access to the Seeed Studio Grove ecosystem by connecting it to the compatible Seeed Studio XIAO expansion board. We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs. For example, you can make a BLE AI-driven Smartwatch Detecting Potential Sun Damage by connecting the Seeed Studio XIAO nRF52840 with an expansion board, and a Grove - UV Sensor. Get started and explore the infinite possibilities of the Seeed Studio XIAO series!
If you are interested in programming embedded machine learning, we have Codecraft visual programming that can help you quickly start your own TinyML project. And we have set up a #tinyml channel on our Discord server, please click to join for 24/7 making, sharing, discussing, and helping each other out.
仕様
Product
XIAO ESP32-C6
XIAO ESP32-C3
XIAO ESP32-S3
Processor
Espressif ESP32-C6 SoC
Espressif ESP32-C3 SoC
Espressif ESP32-S3R8 SoC
two 32-bit RISC-V processors, with the high-performance one running up to 160 MHz, and the low-power one clocking up to 20 MHz
RISC-V single-core 32-bit chip processor with a four-stage pipeline that operates at up to 160 MHz
Xtensa LX7 dual-core, 32-bit processor running up to 240 MHz
Wireless
Complete 2.4GHz Wi-Fi 6 subsystem
Complete 2.4GHz Wi-Fi subsystem
Bluetooth Low Energy 5.0
Zigbee,Thread,IEEE 802.15.4
On-chip Memory
512KB SRAM & 4MB Flash
400KB SRAM & 4MB Flash
8MB PSRAM & 8MB Flash
Interface
1x UART
1x LP_UART
1x IIC
1x LP_IIC
1x SPI
11x GPIO(PWM)
7x ADC
1xSDIO
1x UART
1x IIC
1x SPI
11x GPIO(PWM)
4x ADC
1x UART
1x IIC
1x SPI
11x GPIO(PWM)
9x ADC
1x User LED
1x Charge LED
1x Reset button
1x Boot button
Dimensions
21 x 17.8mm
Power
Input voltage (Type-C): 5V
Input voltage (BAT): 3.7V
Power Consumption Model(Typ.)
(Supply Power: 3.8V)
Modem-sleep Model: 30 mA
Light-sleep Model: 3.1 mA
Deep Sleep Model: 15 μA
Modem-sleep Model: 24 mA
Light-sleep Model: 3 mA
Deep Sleep Model: 44 μA
Modem-sleep Model: 27 mA
Light-sleep Model: 2 mA
Deep Sleep Model: 14 μA
Working Temperature
-40°C ~ 85°C
-40°C ~ 85°C
-40°C ~ 65°C
ハードウェア概要
Onboard
PinOut
用途
Secure and Connected Smart Home, enhancing everyday life through automation, remote control, and more
Space-limited and Battery-Powered Wearables, thanks to their thumb-size and low-power consumption
Wireless IoT Scenarios, enabling rapid, reliable data transmission
認証
HSCODE8543709990
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
Seeed Studio XIAO ESP32C6
x1
7 Pin Header
x2
Note: Starting September 2, Seeed Studio XIAO ESP32SC6  shipped from CN Warehouse will include 2 free aluminum heat sinks. Overseas warehouses may ship a mix of old and new versions.
We are putting the spotlight on Seeed's self-developed Home Assistant-compatible products, offering affiliates 10% commission on referred sales. Sign up to earn more today!
Seeed Studio XIAO ESP32-C6
SKU 113991254
XIAO ESP32-C6 is a cost-effective MCU based on Espressif’s ESP32-C6. This compact MCU excels in Matter-compliant smart home applications with its support for various wireless connectivity (2.4GHz Wi-Fi 6, BLE 5.0, Zigbee, and Thread). Designed with the thumb-size footprint and a single-sided mount of the XIAO Series, it's perfect for space-limited projects. Encrypted on the chip, the XIAO ESP32-C6 ensures a desired level of security streamlined development experience, and swift market entry by integrating easily with major IoT Cloud platforms.
XIAO Dev Board
Pin Header
Package
USD$5.20
product.detail.alsoAdd.title
