Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:
Would need 12V 300W Power Supply with XT60 connector or loose wires for screw terminals. Customers can purchase LRS-350-12 12V 29A Power Supply as power supply option.
You must use the power supply we recommend. We accept no responsibility for any robotic arm malfunctions, damage, or safety issues caused by the use of power supplies from other brands.
  • Pre-assembled Provides ready-to-use 7 DOF robot follower arm for human training, which is the perfect end-to-end learning.
  • Real-world task capable Could be used for real-world grasping taks with 750g working payload and 670mm reach.
  • Self-sustaining suspension Arms could be held at any position after pressing the button, enabling easier data collection.
  • LeRobot framework compatible Provides SDK under Huggingface Lerobot framework for easier data collection and training.
  • Supported ROS2, Moveit2 and Isaac Sim It supports ROS2 for publishing and subscribing to robotic arm data topics and controlling the robotic arm, and also supports MoveIt2 for inverse kinematics calculation, as well as simulation in Isaac Sim.
  • Open-Source SDK Supports Python and C++ SDK Development.
Note: Power Adapter NOT included. Follower Arm needs a 12V 300W Power Supply with XT60 connector or loose wires for screw terminals.
Module
Follower Arm | Cello
Degrees of Freedom
6+1
Reach
670mm
Payload
750g (with 70% reach)
Repeatability
2mm
Servos
RX18-U100H-M x3
RX8-U50H-M x2
RX8-U51H-M x2
Parallel Gripper Kit
Wrist Rotate
Hold at any Position
Wrist Camera Mount
Works with LeRobot
Works with ROS2
Works with Movelt
Works with Gazebo
Communication Hub
UC-01
Power Supply
12V / 300W (XT60 / Screw Terminal)
Weight
3.15kg
Operating Temperature
-10℃~60℃
Hardware Overview
Application
Imitation learning and Reinforcement learning
The LeRobot framework is compatible with the Fashionstar star arm. It provides complete data collection, training, and deployment for teaching the robotic arm, and also has a comprehensive simulation platform. On the Nvidia Jetson edge device, it's easy and quick to train a customized robotic arm to complete grasping and placing tasks. For detailed tutorials, please refer to: LeRobot - NVIDIA Jetson AI Lab
Certification
HSCODE9023009000
USHSCODE9023000000
UPC
EUHSCODE9023001000
COOCHINA
Follower Arm Cello
x1
Follower Arm Cello gripper
x1
Cubes
x4
F clamps
x2
Allen wrench
x1
Screw pack
x1
Copper ring to XT60 power cable
x1
Note: Power Adapter NOT included.Follower Arm needs a 12V 300W Power Supply with XT60 connector or loose wires for screw terminals.
Fashionstar StarAi 7 DoF Robot Follower Arm Cello, compatible with Hugging Face LeRobot
SKU 100049805
Fashionstar StarAi Arm Cello is an affordable pre-assembled servo-based 7 DOF robotic follower arm that is perfect for end-to-end learning. It can be trained to complete real-world grapsing tasks, with a 750g working payload and great positional accuracy. It is a pre-assembled follower arm that can be used for training. It can be used under Huggingface LeRobot framework and ROS2.
JPY¥221425.00
