Note:
Module | Follower Arm | Viola |
Degrees of Freedom | 6+1 |
Reach | 470mm |
Payload | 300g (with 70% reach) |
Repeatability | 2mm |
Servos | RX8-U50H-M x2 RA8-U25H-M x4 RA8-U26H-M x1 |
Parallel Gripper Kit | √ |
Wrist Rotate | √ |
Hold at any Position | √ |
Wrist Camera Mount | √ |
Works with LeRobot | √ |
Works with ROS2 | √ |
Works with Movelt | √ |
Works with Gazebo | √ |
Communication Hub | UC-01 |
Power Supply | 12V / 120W (XT30 / Screw Terminal) |
Weight | 1.1kg |
Operating Temperature | -10℃~60℃ |
Note:
Imitation learning and Reinforcement learning
The LeRobot framework is compatible with the Fashionstar star arm. It provides complete data collection, training, and deployment for teaching the robotic arm, and also has a comprehensive simulation platform. On the Nvidia Jetson edge device, it's easy and quick to train a customized robotic arm to complete grasping and placing tasks. For detailed tutorials, please refer to: LeRobot - NVIDIA Jetson AI Lab
| HSCODE | 9023009000 |
| USHSCODE | 9023000000 |
| UPC | |
| EUHSCODE | 9023001000 |
| COO | CHINA |
Follower Arm Viola | x1 |
Follower Arm Viola gripper | x1 |
Cubes | x4 |
C clamp | x1 |
Allen wrench | x1 |
Screw pack | x1 |
UC-01 debugging adapter board | x1 |
UC-01 debugging adapter board(backup) | x1 |
Note:
Power Adapters NOT included.Would need 12V10A Power Adapters with XT30 connector or loose wires for screw terminals.
Fashionstar StarAi Arm Viola is an affordable pre-assembled servo-based 7 DOF robotic follower arm that is perfect for end-to-end learning. It can be trained to complete real-world grapsing tasks, with a 300g working payload and great positional accuracy. It is a pre-assembled follower arm that can be used for training. It can be used under Huggingface LeRobot framework and ROS2.
