おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
  • The official NVIDIA Jetson Nano Developer Kit has reached EOL and is no longer available for purchase. We recommand you check out this reComputer J10 full system as a replacing choice for Jetson Nano developer Kit.
  • If you are looking for the version with power adapter, please check out reComputer J1020v2 Edge device.
仕様
Jetson Nano 4GB System on Module
Al Performance
Jetson Nano 4GB - 0.5 TOPS
GPU
NVIDIA Maxwel™ architecture with
128 NVIDIA CUDA® cores
CPU
Quad-core ARM Cortex-A57 MPCore processor
Memory
4 GB 64-bit LPDDR4 25.6 GB/s
Video Encoder
1x 4K30 | 2x1080p60 | 4x1080p30
| 4x720p60 | 9x720p30 (H.265 & H.264)
Video Decoder
1x 4K60 | 2x 4K30 | 4x 1080p60 | 8x 1080p30
| 9x 720p60 (H.265 & H.264)
Carrier Board
Storage
1x M.2 Key M PCIe
16G eMMc
Networking
Ethernet
1x RJ-45 Gigabit Ethernet (10/100/1000M)
I/O
USB
4x USB 3.0 Type-A ;
1x Micro-USB port for device mode
Camera
2x CSI (2-lane 15pin)
Display
1x HDMI Type A; 1x DP
Fan
1x 4 pin Fan Connector (5V PWM)
Multifunctional Port
1x 40-Pin Expansion header
1x 12-Pin Control and UART header
Power
9-12V DC
Mechanical
Dimensions (W x D x H)
130 mm x 120 mm x 58.5 mm (with case)
Installation
Desk, wall-mounting
Operating Temperature
0℃ ~ 60℃
Note:
If use some GPIO libraries that causes floating voltage 1.2V~2V , GPIO issues on the carrier board could happen as the normal voltage should be 3V. This is a common situation on the carrier boards, for both the reComputer series and official Nvidia Jetson developer kit. Thus, aftersales / warrenty does not come into effect regarding this isssue. For further information, refer to NVIDIA official document.
ハードウェア概要
  • Desktop, Wall Mount, Expandable, or Fit in Anywhere
用途
Application Fields:
  • Computer Vision
  • Machine Learning
  • Autonomous Mobile Robot (AMR)
認証
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471800000
COOCHINA
部品リスト
reComputer J1020 v2 (System Installed)
x1
*We will not include a 3V RTC battery
reComputer J1020 v2 (w/o power adapter) - Edge AI Computer with NVIDIA® Jetson Nano 4GB
SKU 110061481
A hand-sized edge AI box with 0.5 TFLOPs of power, built with the NVIDIA Jetson Nano 4GB production module. It features a rich set of IOs, an aluminum case, a passive heatsink, pre-built Jetpack 4.6.1, onboard 16 GB eMMC, 2x SCI, 4x USB 3, M.2 Key M, HDMI, and DP.
Processor
Memory
Power Adapter
JPY¥42893.00
product.detail.alsoAdd.title
