The RPLiDAR C1M1-R2 Portable ToF Laser Scanner Kit is an advanced 360-degree 2D laser scanner (LIDAR) solution. It is based on the laser flight-of-time (TOF) ranging principle, offering high-speed rotation, allowing it to capture up to 5000 samples of laser ranging per second. By incorporating contactless power and signal transmission technology, it overcomes the limitations of traditional LIDAR systems, ensuring long-term stability and reliability.
With a measurement distance of up to a 12-meter radius and a minimal blind range of 0.05 meters, the RPLiDAR C1M1 excels in scanning, measuring objects at various distances, and achieving obstacle avoidance.
Its scanning frequency of 10Hz (600rpm) enables a sample rate of 5KHz and an angular resolution of 0.72°. It provides 2.5D multidimensional information, including position information data and reflectivity data.
Each RPLiDAR C1M1 undergoes rigorous testing to ensure compliance with the eye-safety standard of IEC-60825 Class 1, guaranteeing the laser output power is safe for human eyes.
The versatility of the RPLiDAR C1M1 makes it suitable for diverse applications, including home robots, educational ROS cars, commercial robots, autonomous vehicles in low-speed parks, and parking lot space monitoring. Despite its powerful performance, it features a compact and agile design with low noise and vibration levels, facilitating easy integration into a wide range of applications.
Specification | Detail |
Distance Range | White object: 0.05-12 meters (under 70% reflection) |
Black object: 0.05-6 meters (under 10% reflection) | |
Sample Rate | 5KHz |
Scanning Frequency | 8~12Hz, 10Hz@typical |
Angular Resolution | 0.72°@typical |
Scan Field Flatness | 0°~1.5° (can be customized) |
Communication Interface | TTL UART |
Communication Speed | 460800 |
Accuracy | ±30mm |
Resolution | 15mm |
Degree of Protection | IP54 |
Ambient Light Limit | 40,000lux |
RPLiDAR C1M1-R2 Portable ToF Laser Scanner Kit - 12M Range | x1 |
USB Type-C Cable | x1 |
USB Board | x1 |
| HSCODE | 9031499090 |
| USHSCODE | 9031499000 |
| UPC | |
| EUHSCODE | 9013101000 |
| COO | CHINA |
The RPLiDAR C1M1 is a compact 360-degree 2D laser scanner (LIDAR) that provides 2.5D multidimensional information, including position and reflectivity data. Its scanning frequency of 10Hz enables a sample rate of 5KHz and precise angular resolution of 0.72°. With a 12-meter measurement radius and a sampling frequency of 5000 times per second, it is suitable for robot positioning, mapping, navigation, and obstacle avoidance.
