おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Attention
The product page is updated.Please click on the latest product link "RPLiDAR A1M8-R6" to purchase.
  • Measures distance data in more than 8000 times/s
  • 360 Degree Omnidirectional Laser Range Scanning
  • 8000 times sample rate, the highest in the current economical LIDAR industry
  • OPTMAG Original Design, prolong the life-span
  • Configurable Scan Rate from 2-10Hz
  • Ideal for Robot Navigation and Localization
  • Plug and Play
RPLIDAR A1 is a low cost 360-degree 2D laser scanner (LIDAR) solution developed by SLAMTEC. The system can perform a 360degree scan within a 6meter range. The produced 2D point cloud data can be used in mapping, localization, and object/environment modeling.
RPLIDAR A1’s scanning frequency reached 5.5 Hz when sampling 360 points each round. And it can be configured up to 10 Hz maximum.
RPLIDAR A1 is basically a laser triangulation measurement system. It can work excellently in all kinds of indoor environments and outdoor environments without sunlight.
For your convenience, we made a table comparing different RPLiDARs so you can easily pick one that suits your project!
ItemMeasurement Performance
Distance RangeMeasurement ResolutionAngular ResolutionSample RateWorking Environment
RPLIDAR A1M8 - R60.15m -12m<0.5 mm<1% of actual distance *≤1°2000 – 8000 HzIndoor
RPLIDAR A2M60.2m – 18m<0.5 mm<1% of actual distance *≤0.9°2000 – 8000 HzIndoor
RPLIDAR A2M80.15m -12m<0.5 mm<1% of actual distance *≤0.9°2000 – 8000 HzIndoor
RPLIDAR A3M1White Objects:25 mBlack Object: 10 m0.225°16 kHz or 10 kHzIndoor & Outdoor
RPLIDAR S1White Objects: 40mBlack Object: 10m3cm0.313°-0.587°9200 HzIndoor & Outdoor
RPLIDAR S2White Objects: 30mBlack Object: 10m5cm0.12°32 kHzIndoor & Outdoor
SLAMTEC MAPPER M1M120m5cm7000 HzIndoor & Outdoor
SLAMTEC MAPPER M2M140m5cm9200 HzIndoor & Outdoor
Application Scenarios
  • Home service /cleaning robot navigation and localization
  • General robot navigation and localization
  • Smart toy’s localization and obstacle avoidance
  • Environment scanning and 3D re-modeling
  • General simultaneous localization and mapping (SLAM)
認証
HSCODE9031900090
USHSCODE9031902100
UPC841454120919
EUHSCODE9013101000
COOCHINA
技術詳細
Dimensions98.5mm x70mm x60mm
WeightG.W 170g
BatteryExclude
Distance Range0.15 - 6m,White objects
Angular Range0-360 Degree
Distance Resolution<0.5mm
Angular Resolution≤1Degree
Sample Duration0.5ms
Sample Frequency2000~2010Hz
Scan Rate1~10Hz,Typical 5.5Hz,
部品リスト
RPLIDAR A1(PWM motor driver embedded)1
USB Adapter1
RPLIDAR A1 communication cable1
RPLiDAR A1M8 360 Degree Laser Scanner Kit - 12M Range
SKU 110991065
Note: This product has been replaced by an upgraded version, RPLiDAR A1M8-R6. Click here for more details.
USD$99.00
product.detail.alsoAdd.title
