おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Note
Slamtec Mapper M2M2 is the newest version of Slamtec Mapper M2M1, The main difference is that the version M2M2  can support  5V power supply and the version M2M1 supports wide voltage and POE power supply. The performance, size, outlook between M2M2 and M2M1 are not different.
Key Features
  • Large Scenarios and High-quality Mapping
  • Industry grade LiDAR, 2 times detecting range further than M1M1, and higher sample rate.
  • Plug and play, without any external dependence
  • Can be used as a mapper as well as a laser range scanner
  • Connected with WiFi or Ethernet, easy communication
  • Fully Compatible with ROS, Easy Data Analysis
  • Strong stability: work well in fast speed and in the tilting scenarios
Slamtec Mapper M2M2 is an industrial-grade LiDAR. Different from the normal LiDAR, M2M2 has the ability to work in some severe surroundings. SLAMTEC Mapper uses high-performance SLAM map optimization engine and SharpEdge™ fine-mapping technology, which can actively detect and correct closed-loop, and achieve 100,000 square meters high-precision map and pose. SLAMTEC Mapper can work without additional sensors or data input. Because of the built-in 9-DOF inertial navigation system, SLAMTEC Mapper in the hand-held mapping mode can work normally in a fluctuating environment with inclination, to ensure the best map data quality.
SLAMTEC Mapper provides a complete SDK development kit, mobile phone, and PC-side evaluation tools to facilitate users to expand development and data acquisition. At the same time, combined with the supporting ROS driver, the generated map and pose data can be directly used in the ROS environment, which is fully compatible.
Slamtec Mapper adopts SLAMTEC third-generation high-performance SLAM graph optimization engine and SharpEdge™ mapping technology to realize a high accurate thousand-square-meter map building and real-time localization, and it can actively detect the closed-loop and correct map. The mapper is an ideal choice for users to realize mapping and re-localization in various complicated scenarios and output map and localization data that meets users' expectations.
Tilting Compensation and Fast Moving
With a built-in inertial navigation system with nine degrees of freedom, Slamtec Mapper can work properly in tilting and shaky hand-held mode and ensure an excellent map data quality. In addition, it supports to move fast with a maximum speed of 2m/s.
Indoor and Outdoor Availability
Whether in a complicated indoor environment or an outdoor environment with direct daylight, Slamtec Mapper shows a good performance in mapping and localization in those complicated scenarios.
Slamtec Mapper provides completed cross-platform SDK and tools both on the phone and PC side for users to evaluate, develop and use. Through a matched ROS driver, you can integrate the generated map and localization data into the ROS environment seamlessly.
More Than A Mapper
Slamtec Mapper is not only a mapper for mapping and localization, but you can also use it directly as a laser range scanner. Via SDK or ROS node, you can easily put the data of the laser range scanner into the user's current system.
Built-in WIFI, Ethernet port, Easy communication
With built-in access point and station mode WiFi as well as 100M Ethernet port, you can get the real-time map and localization data generated by Slamtec Mapper through the designed mobile application.
Specification Compared with Slamtec Mapper M1M1
ModelM1M1M2M2
Distance Range20m40m
Sample Rate7K9.2K
Max Mapping Area300m x 300m300m x 300m
Resolution5cm5cm
Max Moving Speed1m/s2m/s
Max Rotate SpeedTBDTBD
Re-localization Accuracy<0.02m<0.02m
Map Optimization DurationAbout 1 hourAbout 1 hour
Slope Angle±3°±3°
Data Refresh Rate8Hz10Hz
Comparing Different RPLiDARs
For your convenience, we made a table comparing different RPLiDARs so you can easily pick one that suits your project!
ItemMeasurement Performance
 Distance RangeMeasurement ResolutionAngular ResolutionSample RateWorking Environment
RPLIDAR A1M8-R60.15m -12m<0.5 mm≤1°2000-8000 HzIndoor
<1% of actual distance *
RPLIDAR A2M60.2m – 18m<0.5 mm≤0.9°2000-8000 HzIndoor
RPLIDAR A2M80.15m -12m<0.5 mm≤0.9°2000-8000 HzIndoor
RPLIDAR A3M1White objects: 25 m 0.225°16 kHz or 10 kHzIndoor & Outdoor
Black objects: 10 m
RPLIDAR S1White Objects: 40m3cm0.313°-0.587°9200 HzIndoor& Outdoor
Black Objects: 10m
RPLIDAR S2White Objects: 30m5cm0.12°32 kHzIndoor& Outdoor
Black Objects: 10m
SLAMTEC MAPPER M1M120m5cm 7000 HzIndoor & Outdoor
SLAMTEC MAPPER M2M240m5cm 9200HzIndoor & Outdoor
Dimensions
  • 1x Slamtec Mapper M2M2 Edition - Laser Mapping Sensor
Note
Please download the offline version of Robostudio while testing. Click here: RoboStudio 20 v1.7.5_rtm.rar
認証
HSCODE9031499090
USHSCODE9031499000
UPC
EUHSCODE9013101000
COOCHINA
Slamtec Mapper M2M2 - LiDAR Mapping Sensor(Industrial Grade) - 40M Range
SKU 101990641
USD$699.00
product.detail.alsoAdd.title
