製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
RPLIDAR S2 is a 360-degree DToF(Time of Flight) laser sensing scanner that samples up to 32 kHz, capable of generating 2D point cloud map information up to 18m radius, within 30 mm precision, for up to 5 years. It suits for anywhere, for both indoor and outdoor installation, with small, compact, high light resistance, reliable IP65, and Class One eye safety rating design.
This next-generation low-cost, high-performance laser scanner will be your great instrument in mapping, robot positioning, navigation, object/environment modeling, or other practical applications.
Feature
  • 360 Degree DToF Laser Ranging Scanner: Generate 2D point cloud map information up to 18m radius, within 30mm precision
  • Stunning Sampling Capability: Up to 32KHz measurement frequency, 10Hz rotational speed, resist up to 80000 lux light
  • Prolong Operation Life: Apply OPTMAG light magnetic fusion technology for support up to five years of reliable running
  • Suitable for Anywhere: IP65 high ingress protection, small and compact, capable of every indoor and outdoor deployment
  • Certified Output Laser Power: Safe as IEC-60825 Class One eye safety rating
RPLIDAR S2L comes with an upgraded product, by increasing the operating performance of hardware and optimizing the internal algorithms. It applies the Direct Time of Flight(DToF) theory that emits and receives the laser pulse to measure the distance by calculating the flight time. Compared to Triangulation Laser Sensor, it performs much higher precision, higher sampling frequency, and longer measuring distance.
As it to say, what the RPLIDAR S2L brings 360 degrees, 18M radius, 32 kHz light detection and ranging, 0.12 angular resolution by 10Hz rotational speed, within 30mm sensing precision, for 5 years of reliable running.
It implements 2D point cloud map information generating and you can deploy it to map, navigate, position robots, model objects,s or other practical use. By its small and compact structure, along with its IEC-60825 Class 1 eye safety rating, the RPLIDAR S2L can perform high standards of operation in your property of which the output laser power is harmless to the human eye.
The IP65 design of this precision mechanical equipment is well protected from foreign bodies such as tools, dirt, and liquid water. Additionally, it retains its functionality against high-intensity 80000 lux light. All of these make it suitable for outdoor and field installation, especially capable of working under the big sun on sunny days.
By the sense of its line and science, it will be your ideal choice for architecture exploration.
Application
  • Robot navigation and obstacle avoidance
  • Obstacle detecting and avoiding AGV
  • Parking lot monitoring
  • Environment perception and autonomous movement of low-speed unmanned vehicles
  • Multi-point touching and man-machine interaction
  • UV mapping and obstacle avoidance
  • Environment scanning and 3D rebuilding
RPLIDAR S2 Series Comparison
RPLIDAR Model
S2M1
S2L
S2E
Recommended
applications
Commercial robot,
Outdoor robot
Commercial robot,
Outdoor robot
Commercial robot,
Outdoor robot
Measuring Range
0.05m - 30m
0.05m - 18m
0.05m - 30m
Sampling Frequency
32K
32K
32K
Rotational Speed
10Hz
10Hz
10Hz
Angular Resolution
0.12°
0.12°
0.12°
OPTMAG Supported
Motor
Brushless
Brushless
Brushless
Motor Driving Supported
Dimensions
77 x 77 x 38.5 mm
77 x 77 x 38.5 mm
77 x 77 x 38.5 mm
Weight
190g
190g
190g
Connect
TTL UART Serial (3.3 voltage level)
Ethernet UDP
System Voltage
5V
5V
12V
System Current
400mA
400mA
200mA
Power Consumption
> 2W
> 2W
> 2W
Temperature Range
-10℃ - 50℃
-10℃ - 50℃
-10℃ - 50℃
Angular Range
360°
360°
360°
Scan Field Flatness
±1.5°
±1.5°
±1.5°
Range Resolution
13mm
13mm
13mm
Accuracy
≤30mm
≤30mcm
≤30mm
RPLiDAR S2L 360 Degree Laser Range Scanner
x1
USB adapter
x1
Micro-USB cable
x1
Power cable
x1
Note
Please download the offline version of Robostudio while testing. Click here: RoboStudio 20 v1.7.5_rtm.rar
Does the new generation RPLIDAR S series product compatible with other RPLIDAR A series?
Yes, they share the same connectors and are completely compatible with other RPLIDAR A series products.
認証
HSCODE9031499090
USHSCODE9031499000
UPC
EUHSCODE9013101000
COOCHINA
RPLiDAR S2L 360 Degree Laser Range Scanner - 18M Range, 2D point cloud map, 80000 lux light resistance, IP65, high safety for human eye
SKU 101110081
JPY¥47324.00
廃番
