製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
RPLIDAR A2M12 is a 360-degree triangulation laser sensing scanner that samples at up to 16 kHz, capable of generating 2D point cloud map information for a 12m radius, within low precision, and running for up to 5 years. This next-generation low-cost, high-performance laser scanner will be your great instrument for in-home robots, 3D modelling, etc.
  • 360 Degree Triangulation Laser Sensor Ranging Scanner: Generate 2D point cloud map information for 12m radius, 0.225° angular resolution
  • Distinguished Sampling Capability: Equip high-speed RPVision3.0 range engine, for up to 16KHz measurement frequency, 5 ~ 15Hz adjustable rotational speed
  • Prolong Operation Life: Apply OPTMAG light magnetic fusion technology for support up to five years of reliable running
  • Certified Output Laser Power: Safe as IEC-60825 Class One eye safety rating
  • Cup-size Design: Light & portable, 4cm ultra-thin shell, even can be placed on floor mopping robot
RPLIDAR A2M12 applies the Triangulation Laser Sensing theory that emits and receives laser to measure the distance by calculating the receiving time. By embedded high-speed RPVision3.0 range engine, the RPLIDAR A2M12 offers 360 degrees, 12M radius, 16 kHz light detection and ranging, 0.225° angular resolution(10Hz) with 5 ~ 15Hz adjustable rotational speed, low sensing precision, 5 years reliable operation for the generation of 2D point cloud map information.
With the new brushless motor non-contact drive, the RPLIDAR A2M12 works with ultra-low noise. Additionally, its output laser power is as safe as IEC-60825 Class One eye safety. All of these make it an excellent tool for you to conduct positioning and obstacle detection. Being cup-size and light as 190g, it can be placed anywhere in your home or deployed on a domestic robot like a floor mopping robot, or home care robot.
This low-cost 2D laser scanner (LIDAR) remains high-performance and will be a great assistance to your demonstration of navigation and positioning.
Comparing 6 Different RPLiDARs
For your convenience, we made a table comparing 6 different RPLiDARs so you can easily pick one that suits your project!
Item
Measurement Performance
Distance Range
Measurement Resolution
Angular Resolution
Sample Rate
Working Environment
RPLIDAR A1M8-R6
0.15m -12m
<0.5 mm
≤1°
2000-8000 Hz
Indoor
<1% of actual distance *
RPLIDAR A2M8
0.15m -12m
<0.5 mm
≤0.9°
2000-8000 Hz
Indoor
RPLiDAR A2M12
0.2m-12m
<0.5 mm
0.225°
16 kHz
Indoor
RPLIDAR A3M1
White objects: 25 m
0.225°
16 kHz or 10 kHz
Indoor & Outdoor
Black objects: 10 m
RPLIDAR S1
White Objects: 40m
3cm
0.313°-0.587°
9200 Hz
Indoor& Outdoor
Black Objects: 10m
RPLIDAR S2
White Objects: 30m
5cm
0.12°
32 kHz
Indoor& Outdoor
Black Objects: 10m
SLAMTEC MAPPER M1M1
20m
5cm
7000 Hz
Indoor & Outdoor
SLAMTEC MAPPER M2M1 Pro
40m
5cm
9200Hz
Indoor & Outdoor
Application
  • General robot navigation and localization
  • Environment scanning and 3D re-modeling
  • Service robots or industrial robots working for long hours
  • Home service /cleaning robot navigation and localization
  • General simultaneous localization and mapping (SLAM)
  • Smart toy localization and obstacle avoidance
Dimensions
76mm x76mm x41mm
Weight
G.W 190g
Battery
Exclude
Distance Range
0.2 - 12m, Based on white objects with 70% reflectivity
Angular Range
0-360 Degree
Distance Resolution
<0.5mm
Angular Resolution
0.225 degree
Sample Duration
0.25ms
Sample Frequency
16000Hz
Scan Rate
5~15Hz,Typical 10Hz
A2M12 RPLIDA
R(PWM motor driver embedded)
1
USB Cable
1
DC Cable
1
Adapter Driver Board
1
Note
Please download the offline version of Robostudio while testing. Click here: RoboStudio 20 v1.7.5_rtm.rar
How come my product is not working since arrive and when I connect the PC there doesn't show any port?
Please check if the driver has been installed on your PC, or you can re-download the software.
認証
HSCODE9031499090
USHSCODE9031499000
UPC
EUHSCODE9013101000
COOCHINA
RPLiDAR A2M12 360 Degree Laser Scanner Kit - 12M Range
SKU 114110128
RPLIDAR A2M12 is a 360-degree triangulation laser sensing scanner that samples at up to 16 kHz, capable of generating 2D point cloud map information for a 12m radius, within low precision, and running for up to 5 years. This next-generation low-cost, high-performance laser scanner will be your great instrument for in-home robots, 3D modeling, etc.
JPY¥36245.00
