製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • High-speed laser ranging sampling capability of 32,000 times per second
  • Non-contact energy and signal transmission technology
  • Reliable and stable operation for a long time
  • Coverage area with a radius of 30 meters on a two-dimensional plane
  • 360° omnidirectional laser ranging scanning
  • Excellent application in both indoor and outdoor environments
  • Built-in speed detection and adaptive system
  • Cost reduction because there is no need to provide a complex power supply system
  • The emitted laser power complies with IEC-60825 Class 1 human eye safety level
RPLIDAR S2 is a new generation of low-cost two-dimensional laser ranging radar (LIDAR), which can perform a 360-degree omni-directional laser ranging scan within a 30-meter radius of a two-dimensional plane, and generate a flat point cloud map of the space in which it is located information. These cloud map information can be used in practical applications such as map surveying and mapping, robot positioning and navigation, and object/environment modeling.
RPLIDAR S2 adopts laser time-of-flight ranging technology, coupled with the high-speed laser acquisition and processing mechanism developed by SLAMTEC, which can perform 32,000 ranging actions per second. It uses non-contact energy and signal transmission technology, overcomes the life limitation of traditional lidar, and can operate reliably and stably for a long time.
Compared with other series of lidars, RPLIDAR S2 has more stable ranging performance when detecting long-distance objects, switching between black and white objects, and strong light directing objects. It can achieve ideal mapping within a 30-meter ranging radius in indoor and outdoor environments. As a result, the scope of application can be expanded to more consumer-level commercial scenarios.
For your convenience, we made a table comparing different RPLiDARs so you can easily pick one that suits your project!
ItemMeasurement Performance
 Distance RangeMeasurement ResolutionAngular ResolutionSample RateWorking Environment
RPLIDAR A1M8-R60.15m -12m<0.5 mm≤1°2000-8000 HzIndoor
<1% of actual distance *
RPLIDAR A2M60.2m – 18m<0.5 mm≤0.9°2000-8000 HzIndoor
RPLIDAR A2M80.15m -12m<0.5 mm≤0.9°2000-8000 HzIndoor
RPLIDAR A3M1White objects: 25 m 0.225°16 kHz or 10 kHzIndoor & Outdoor
Black objects: 10 m
RPLIDAR S1White Objects: 40m3cm0.313°-0.587°9200 HzIndoor& Outdoor
Black Objects: 10m
RPLIDAR S2White Objects: 30m5cm0.12°32 kHzIndoor& Outdoor
Black Objects: 10m
SLAMTEC MAPPER M1M120m5cm 7000 HzIndoor & Outdoor
SLAMTEC MAPPER M2M1 Pro40m5cm 9200HzIndoor & Outdoor
Application
  • Universal simultaneous positioning and mapping (SLAM)
  • Environmental scanning and 3D reconstruction
  • Service robots and industrial fields that need to work continuously for a long time
  • Navigation and positioning of home care/cleaning robots
  • General robot navigation and positioning
  • Positioning and obstacle detection of smart toys
Parameters
Details
Measuring distance
White object:30m
Black object:10m
Sampling frequency
32kHz
Scanning frequency
10Hz
Angle resolution
0.12°
Communication interface
TTL UART
Communication rate
1M
Measurement accuracy
±5cm
Supply voltage
5V
Supply voltage ripple
20-50mV
System startup current
1500mA
Supply current
40mA(5V power supply, during sleep)
400mA(5V power supply, working)
Communication interface input and output voltage
3.3V
Range of working temperature
-10℃ to 50℃
Weight
190g
Mechanical dimension drawing
RPLIDAR S2 module (built-in PWM motor driver)
1
USB adapter
1
Micro-USB cable
1
Power cable
1
Note
Please download the offline version of Robostudio while testing. Click here: RoboStudio 20 v1.7.5_rtm.rar
認証
HSCODE9031499090
USHSCODE9031499000
UPC
EUHSCODE9013101000
COOCHINA
RPLiDAR S2 Low Cost 360° Laser Range Scanner - 30M Range
SKU 114992738
RPLIDAR S2 is a new generation of low-cost two-dimensional laser ranging radar, which can perform a 360-degree omni-directional laser ranging scan within a 30-meter radius of a two-dimensional plane, and generate a flat point cloud map of the space in which it is located information. It can be used in practical applications such as map surveying and positioning and navigation.
JPY¥63152.00
