おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
The Grove Water Level Sensor is a very accurate sensor that can be helpful in water level sensing applications. It is completely waterproof and uses capacitive pads to detect water levels up to 10cm.
  • High measurement accuracy: Since the sensor is based on capacitive sensing, The measurement accuracy is up to ±5 mm.
  • Outstanding corrosion resistance: Inevitably, some liquids may be corrosive during use, and with the help of corrosion-resistant materials, the sensor can be used for a long time.
  • Grove unified socket: The sensor ensures "Plug and Play" and could be versatile for various applications.
We used capacitive pads on the PCB of the module and did conformal coating over the PCB to make the sensor protect against moisture, dust, chemicals and high temperatures. We believe that this technique will allow you to make accurate water level measurements (±5mm accuracy) easily
Let’s look at the difference between few water level sensing methods.
 Ultrasonic Distance SensorSensor based on ResistanceGrove - Water Level Sensor
PrincipleUltrasonic WavesResistanceCapacitance
Communication InterfaceDigitalAnalogI2C
Operating Voltage3.3/5V3.3/5V3.3/5V
WaterproofNoYesYes
Note
The blue oil layer on the surface of the module’s capacitance sensing area should be kept intact. When the oil layer is damaged and the test object is a conductive liquid, the test data may be abnormal.
Attention
When testing, the highest liquid level inserted should not exceed the white dividing line, otherwise it will cause a short circuit.
Applications
  • Tank overflow detection
  • Liquid level sensing applications
Specifications
Dimensions
20mm x 133mm
Weight
G.W 9.8g
Battery
Exclude
Operating voltage
3.3~5V
Measurement Accuracy
±5mm
Working Temperature Range
-40°C to 105°C
I2C Addresses
0x78 and 0x77
Interface
I2C
Hardware Overview
Grove - Water Level Sensor (10CM) for Arduino
1
Grove Cable
1
認証
HSCODE9026100000
USHSCODE9026102080
UPC841454122883
EUHSCODE9013101000
COOCHINA
SKU 101020635
USD$7.60
product.detail.alsoAdd.title
