おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Looking for a ready-to-use alternative? We recommend the reComputer J401 Nano Bundle. It delivers the same 67 TOPS AI performance and a similar form factor to the NVIDIA Official Developer Kit, with a 256GB NVMe SSD and pre-installed JetPack 6.2 for a quicker start.
Planning for edge AI deployment? Consider the reComputer J3011, an enclosed edge AI computer powered by the Jetson Orin Nano 8GB module. It includes a 128GB SSD and supports up to 67 TOPS after upgrading to JetPack 6.2, making it suitable for deployment and system integration.
Purchase Limit: NVIDIA® Jetson Orin™ Nano Super Developer Kit is limited to 1 unit per customer.
  • Excellent AI Performance for production: low power and low latency with up to 67 TOPS AI performance, featuring an Ampere architecture GPU and a 6-core ARM CPU, which enables multiple concurrent AI application pipelines and high-performance inference.
  • Compact edge AI device: compact size at 100mm x79mm x 21mm, includes Jetson Orin™ Nano 8GB module, a heatsink with a fan and a power adapter.
  • Expandable with rich I/Os: 4x USB 3.2 Gen 2 ports, DP 1.2, M.2 key E with pre-installed Wi-Fi module, 2x M.2 Key M for SSD, microSD slot, 2x MIPI CSI-2 connectors, Gigabit Ethernet, 40-pin GPIO.
Jetson Orin Nano Super Developer Kit configuration
 NVIDIA Jetson Orin Nano Developer Kit (original)NVIDIA Jetson Orin NanoSuper Developer Kit
GPU
NVIDIA Ampere architecture
1,024 CUDA Cores
32 Tensor Cores
635 MHz
NVIDIA Ampere
architecture
1,024 CUDA Cores
32 Tensor Cores
1,020MHz
AI PERF
40 INT8 TOPS (Sparse)
20 INT8 TOPS (Dense)
10 FP16 TFLOPs
67 TOPS (Sparse)
33 TOPS (Dense)
17 FP16 TFLOPs
CPU
6-core Arm Cortex-
A78AE v8.264-bit CPU
1.5 GHz
6-core Arm Cortex-
1.7 GHz
Memory
8GB 128-bit LPDDR5
68GB/s
8GB 128-bit LPDDR5
102GB/s
MODULE POWER7W|15W7W|15W|25W
仕様
Jetson Orin Nano System on Module
AI Performance
Jetson Orin Nano 8GB with SD card slot on module - 67 TOPS
GPU
NVIDIA Ampere architecture with 1024 NVIDIA® CUDA® cores and
32 Tensor cores
CPU
6-core Arm® Cortex®-A78AE v8.2 64-bit CPU 1.5MB L2 + 4MB L3
Memory
8GB 128-bit LPDDR5 102 GB/s
Video Encoder
1080p30 supported by 1-2 CPU cores
Video Decoder
1x 4K60 (H.265) | 2x 4K30 (H.265) | 5x 1080p60 (H.265) | 11x 1080p30 (H.265)
Power
7W-25W
Carrier Board
Storage
1x microSD slot (UHS-1 cards up to SDR104 mode)
Networking
Ethernet
1x Gigabit Ethernet (10/100/1000M)
PCIe
M.2 KEY M
4x PCIe GEN3
2x PCIe GEN3
M.2 KEY E
1x M.2 Key E(pre-installed 1x Wi-Fi/Bluetooth combo module);
PCIe (x1), USB 2.0, UART, I2S, and I2C
I/O
USB
4x Type A USB 3.2 Gen2
1x Type C for UFP
CSI Camera
2x MIPI CSI-2 (22pin)
Display
1x DP 1.2 (+MST) connector
Fan
1x 4 pin Fan Connector (5V PWM)
CAN
1x CAN
Multifunctional Port
1x 40-Pin Expansion header
1x 12-Pin Control and UART header
RTC
RTC 2-pin, supports CR1220 but not included
Power Supply
9V-19V DC
Mechanical (W x D x H)
100mm x 79mm x 21mm
Product Weight
0.176 kg
Warranty
1-year warranty for development use only
用途
  • NVIDIA AI software stack
The NVIDIA AI software stack is designed to accelerate AI application and deployment.
  • Jetson Platform Services
Leverage Jetson Platform Services that provides platform to simplify development, deployment and management of Edge AI applications on NVIDIA Jetson like BEV sensing demo with 4 USB cameras.
  • Jetson AI Lab for Generative AI and Computer Vision Models deployment
Go to Jetson AI lab for one-line deploy projects edge AI applications of generative AI including Ollama, Llama3; computer vision including YOLOv8; and others.
認証
HSCODE8517180050
USHSCODE8517620090
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
NVIDIA Jetson Orin™ Nano Super Developer Kit
x1
19V Power Adapter
x1
Type B (US, JP, CA, PH) Power Cable
x1
Type I (CN) Power Cable
x1
UPC Label
x1
Quick Start and Support Guide
x1
Note: Items not included
  1. microSD card (64GB UHS-1 or bigger recommended)
  2. USB keyboard and mouse
  3. Computer display
  4. USB cable
  5. NVMe SSD card
  6. AC Cloverleaf Power Cord - EU
NVIDIA® Jetson Orin™ Nano Super Developer Kit Bundle |945-13766-0000-000
SKU E26041601
Buy Jetson Orin Nano Super Dev Kit Now and Get a Free Antenna – Antenna Fee Automatically Waived at Checkout.
NVIDIA Jetson Orin Nano Super Developer Kit is a compact edge AI board, built with Jetson Orin™ Nano 8GB module which delivers up to 67 TOPS AI performance--a 1.7X improvement over its predecessor(NVIDIA Jetson Orin Nano Developer Kit). It has a rich set of IOs including USB 3.2 Gen 2 ports, 2x M.2 Key M for SSD, pre-installed Wi-Fi module.
Seeed reComputer Orin Nano Super Dev Kit · 256GB SSD
USD$450.30
NVIDIA® Jetson Orin™ Nano Super Developer Kit (945-13766-0000-000)x1$449.00
2.4G/5G External Antenna with RP-SMA Male Connector and 1.13 Coaxial Cable 130mm Setx1$1.30
product.detail.alsoAdd.title
