おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Robust Hardware Design: A compact, high-performance edge AI computer compatible with NVIDIA Jetson Orin Nano/NX modules in Super/MAXN mode, providing up to 157 TOPS of AI performance.
  • Multiple Interfaces for robotics: Including dual RJ45, M.2 slots for 5G/Wi-Fi/BT modules, 6x USB 3.2, 2x CAN, GMSL2(additional purchase), I2C, and UART, functioning as a powerful robotic brain.
  • Software Setup: Pre-installed with JetPack 6.2 and Linux BSP for seamless deployment.
  • Application and Benefit: Ideal for rapid development of autonomous robots, accelerating time-to-market with ready-to-use interfaces and optimized AI frameworks.
  • Wide Operating Range: Operates reliably across a temperature range of -20°C to 60°C at 25W mode and -20°C to 55°C at 40W mode
    Jetson Modules Performance with Super Mode
    • Enhanced power management
    • Improved higher frame rate processing
    • Reduced inference time
仕様
Carrier Board
Supported Jetson Module
Jetson Orin Nano/Orin NX
Supported Module Power
7W | 10W | 15W | 20W | 25W | 40W
Storage
1x M.2 KEY M PCIe
Networking
M.2 KEY E
1x M.2 Key E for WiFi/Bluetooth module
M.2 KEY B
1x M.2 Key B for 5G module
Ethernet
2x RJ45 Gigabit Ethernet
I/O
USB
6x USB 3.2 Type-A (5Gbps);
1x USB 3.0 Type-C (Host/DP 1.4)
1x USB 2.0 Type-C (Device Mode/Debug);
Camera
1x 4 in 1 GMSL2(mini fakra)(optional board)
CAN
2x CAN0(XT30(2+2))
3x CAN1(4-Pin GH-1.25 Header)
Display
1x DP1.4(Type C Host)
UART
1 x UART 4-Pin GH-1.25 Header
I2C
2x I2C 4-Pin GH-1.25 Header
Fan
1x 4-Pin Fan Connector (5V PWM)
1x 4-Pin Fan Connector (12V PWM)
Extension Port
1x Camera Expansion Header(for GMSL2 board)
RTC
1x RTC 2-pin
1x RTC Socket
LED
3x LED(PWR, ACT and User LED)
Pinhole Button
1x PWR
1x RESET
DIP Switch
1x REC
Antenna Hole
5x Antenna Hole
Power
19-54V XT30(2+2) (XT30 to 5525 DC Jack Cable included)
Jetpack Version
Jetpack 6.2
Mechanical
Dimensions (W x D x H)
115mm x 115mm x 38mm
Weight
200g
Installation
Desk, Wall-mounting
Operating Temperature
-20℃~60℃(25W Mode)
-20℃~55℃(MAXN Mode)
(with reComputer Robotics heat sink with fan)
Warranty
2 Years
Certification
RoHS, REACH, CE, FCC, UKCA, KC
ハードウェア概要
用途
Humanoid Robot & Manipulation:
Serving as a powerful brain for humanoid robots, the reComputer Robotics series delivers rich perception with precise motion control. Emulating human-like sensing, dexterity, mobility and whole-body coordination—seamlessly collaborating with people to get tasks done.
Autonomous Robots, AMRs/ AGVs/ Logistics Robots:
  • The CAN bus links servos or motors to drive Robotic Arms and Autonomous Robots with millisecond-level joint coordination.
  • Logistics Robots map in seconds via UART LiDAR, dodge on the fly and shuttle racks nonstop.
  • I²C weaves temperature, humidity, IMU and fuel-gauge data into a net, giving robots early-maintenance alerts.
  • USB cameras scan barcodes while on the move, and a USB ticket printer labels parcels in real time—zero manual labor from inbound to outbound.
  • Dual-RJ45 link-aggregation delivers video to the Edge AI reCopmputer in <1 ms for real-time QC and remote monitoring.
High-Performance Vision for Robotics:
Combining a GMSL 2 camera with a reComputer Robotics enables advanced vision-based robotics. Sensing 3MP GMSL 2 camera supports real-time object detection, panoramic environment awareness, and multi-camera 3D reconstruction . The high-bandwidth, low-latency GMSL 2 link supports long cable runs and multi-camera setups, while the Jetson Orin NX delivers real-time AI processing for perception, mapping, and control.
3D Vision and GMSL 2 Connectivity for Robotics:
The reComputer Robotics GMSL Extension supports the Orbbec Gemini 335LG Stereo Vision 3D Camera, providing accurate real-time 3D perception for advanced robotics. With the MAX96712 deserializer and mini-FAKRA connector, it ensures secure, low-latency, and reliable data transmission, ideal for AMRs, robotic arms, and collaborative robots. Precise depth sensing enables smarter navigation, robust object recognition, and reliable obstacle avoidance across mobile robots, delivery systems, and shelf-stocking applications.
We have Jetson-example prepared for you! It offers one-line deploy projects edge AI applications of generative AI including Ollama, Llama3; computer vision including YOLOv8, and others. We have configured all environment for you to provides single command deployment of projects.
部品リスト
reComputer Robotics J401 Carrier Board x 1
x1
Power Supply and JST expansion board x 1
x1
XT30 to DC cable x 1
x1
USB Cable, Type A to Type C x 1
x1
Heat Sink for expansion board
x 1
Stud(M3*30)
x 5
M3 Hexagon nut
x 5
Screw(CM2.5*L.4) for Jetson Module and M.2 Key M
x 3
Screw(CM2*3.0) for M.2 Key E
x 1
Stud(M2*2.0) for M.2 Key B
x 1
Screw(CM3*4.0) for M.2 Key B
x 1
User Manual
x 1
reComputer Robotics & optional accessories
SKU E2025052001
The reComputer Robotics J401 is a compact, high-performance edge AI carrier board designed for advanced robotics. Compatible with NVIDIA Jetson Orin Nano/Orin NX modules in Super/MAXN mode, it delivers up to 157 TOPS of AI performance. Pre-installed with JetPack 6.2 and Linux BSP, it ensures seamless deployment, serving as a powerful robotic brain capable of processing complex data from various sensors.
USD$189.00
reComputer Robotics J401 Carrier Board for Jetson Orin Nano/Orin NXx1$189.00
product.detail.alsoAdd.title
