DIY an IoT-connected module can be easy and cost-effective. Here we prepared this bundle kit and a step-by-step guide to help you create a few must-have modules so that you can automate your house. These modules support ESPHome and natively work with an open-source home automation project: Home Assistant, which puts local control and privacy first. Home Assistant turns your Raspberry Pi or any local server like Home Assistant Green, Odyssey Blue, reTerminal into the ultimate home automation hub. With Home Assistant, you can focus on integrating your devices and writing automation.
ESPHome is an open-source project to help you customize smart home solutions based on popular ESP32/ESP8266 boards. We highly recommend exploring the XIAO ESP32C3 or XIAO ESP32S3, both of which offer exceptional compatibility with ESPHome. The XIAO ESP32C3 offers affordability and compact reliability, ideal for budget-friendly smart home setups. The XIAO ESP32S3, with its powerful dual-core processor and extensive interface options, is perfect for more demanding and versatile projects.
There are hundreds of off-the-shelf hardware such as temperature, gas, soil moisture sensors, etc. ESPHome has support for many different sensors. Each of them is a platform of the sensor domain and each sensor has several base configuration options. ESPHome natively integrates with Home Assistant. It reads in a YAML configuration file and creates custom firmware which it installs on your ESP device. Devices or sensors added in ESPHome’s configuration will automatically show up in Home Assistant’s UI. Learn more about ESPHome.
By the way, If you build your ESPHome but using Zigbee/Thread/Matter, consider using the Home Assistant Connect ZBT-2 or Sonoff Zigbee 3.0 USB Dongle Plus–ZBDongle-E for seamless integration. And use Home Assistant Connect ZWA-2 to connect any Z-Wave device to Home Assistant.
This wiki will walkthrough step-by-step on how to connect Seeed Studio XIAO ESP32C3 with ESPHome running on Home Assistant and send the sensor data/ control devices after connecting Grove modules to XIAO ESP32C3. You can also explore a list of Grove modules that support ESPHome. If you opt for the XIAO ESP32S3, we also have a detailed tutorial to guide you through its setup.
What can we do with the included Grove modules in this kit? First of all, we can monitor environmental conditions such as temperature, humidity, CO2, and air quality. Then we can control home appliances using a relay and also detect intruders with a motion detection sensor.
For environmental monitoring, we recommend you 2 options.
However, if you are interested to measure all the environmental conditions, you can choose all AHT20, SGP30, and SCD41. In this situation, you will need an I2C hub because all these 3 Grove modules use I2C for communication, and the Grove Shield only has 2 I2C ports onboard.
When we talk about smart home sensors, temperature & humidity sensor is a must-have! Here we include the Grove - AHT20 I2C Industrial Grade Temperature and Humidity Sensor. You might have heard about the popular DHT11/DHT22, but AHT20 has a more stable performance in harsh environments. In fact, AHT20 is suitable for most industrial scenarios.
Air quality monitoring is helpful if you have asthma or allergies. Knowing the air quality in your area is critical to preventing or treating flare-ups. Buying an air purifier is an option, but measuring the air quality in your room can help determine where you put the air purifier.
The Grove-VOC and eCO2 Gas Sensor SGP30 is an air quality sensor. Based on SGP30, this module provides TVOC(Total Volatile Organic Compounds) and CO2eq output with outstanding long-term stability and low power consumption.
High CO₂ concentrations can affect work performance by causing concentration problems and fatigue. CO₂ concentration also serves as an indicator of the risk of infection with viruses and bacteria. Sensirion's CO₂ sensors enable the development of reliable CO₂ monitors that improve performance and reduce the risk of viral contamination. Grove- SCD41 uses Sensirion’s photoacoustic measurement principle, the CO₂ sensor technology could be miniaturized. The new compact design of the sensor allows easy and flexible integration into air conditioning systems. Apart from CO2 monitoring, Grove - SCD41 can measure temperature and humidity as well.
PIR sensors(also known as PID or passive infrared detector) detect infrared radiation emitted by particles. A passive infrared sensor is an electronic sensor that measures infrared light radiating from objects in its field of view. PIR sensors are commonly used in security alarms and automatic lighting applications where PIR sensors allow you to sense motion to detect whether a human is moving in or out of the sensor range. They are small, inexpensive, low power consumption, easy to use, and stable.
We include the Grove – mini PIR motion sensor, a compact, low power consumption, and cost-effective PIR sensor for applications with relatively less detection distance requirements.
A relay is useful to control a circuit of high voltage with low voltage. For example, control an appliance that runs at 220V by just using 3.3V.
An esphome-connected relay can make any device smart. Yes. ANY! By integrating Grove - Relay into an existing home appliance such as a fan, washing machine, coffee machine, light bulb with the help of the XIAO ESP32C3’s WiFi capability, you can simply turn them ON/OFF remotely.
Grove-all-in-one environmental sensor SEN55 is an integrated Grove ambient sensor, assembling 8 types of environmental signal output, sensing in high accuracy and operating for up to 10 years, born for HVAC and air quality long years detecting applications. Powered by Sensirion, it represents the leading technology in sensing.
The use of mmWave Sensor technology can make home furnishing fully applied in intelligent aspects. It can detect human presence and absence, the motion and the direction of motion, object speed, and detected distance. You can utilize its performance to build your own object movement detection radars or build a Home Assistant with human presence detection in combination with the most popular 24GHz mmWave Sensor. These characteristics make it the best alternative to PIR sensors.
DIY an IoT-connected module can be easy and cost-effective. Here we prepared this bundle kit and a step-by-step guide to help you create a few must-have modules so that you can automate your house. These modules support ESPHome and natively work with an open source home automation project: Home Assistant, which puts local control and privacy first. Home Assistant turns your Raspberry Pi or any local server like Home Assistant Yellow, Odyssey Blue, reTerminal into the ultimate home automation hub. With Home Assistant, you can focus on integrating your devices and writing automation.
